Hey everybody,
Still relatively new to quick capture. Just had a field crew take it out on a trial run to collect point features and they ran into some issues. I have run some tests using both my mobile phone and the android based Trimble field data collection unit they used and ran into the same issues.
First, the tile package base map I used for the project only displays when connected to wifi. You can collect points without wifi, but the map page displays all grey with no current location marker. Second, if you try to connect to public wifi the map page will “loading map” forever which will not allow the points to be sent. Not sure if this is just an issue with the strength of the public wifi not being powerful enough to load the tile package map. Finally, just something to be aware of, the field crew said they got signed out somehow without pressing the sign out button (which would not be good without wifi around). After playing around with the app trying to figure out how this could have happened I realized if you press the information button for a project and then use the back button on your device it will make it appear as if you have signed out. If you close the app and reopen it however, you are still signed in.
Any insight would be appreciated
