I have a parcel layer in the web appbuilder with the attribute table widget enabled. If I click on a record in the attribute table, it will center the map and select the parcel geometry on the map. However, if I click on a parcel on the map first, it won't necessarily select and zoom to the corresponding record in the attribute table, unless it is one of the 25 or so records loaded in the attribute table at the time.
Is this just an unsupported feature at this time? Does anyone know it this attribute table widget functionality will be expanded at the next release?
Dan
