Spatial Views stopped working when we upgraded to 10.1
Hello -
We are a data warehouse environment where we have both business and spatial data inside the same Geodatabase, but the business data is not managed by GDB/SDE. We did that as a design decision, and it was backed up by Esri technical staff. Anyhow, in order to support our GIS applications we have built our own custom Spatial ETL using Python and ArcPy, then at the end of the process the data is loaded to ArcSDE and all of our business and spatial data is joined via a spatial view to be consumed by ArcIMS, ArcGIS Server and .NET. This code has been running for years, and with each upgrade we have handled the changes for Python and ArcGIS Desktop as they came out. ArcGIS 10.1 has thrown us a wrinkle that is killing our process, and it happens in two ways:
1) Our code is taking much longer to process the data, from minutes in some Feature class to HOURS. This is counterproductive to the idea of an upgrade and we will be reviewing the changes in ArcPy from the two versions to see where some code issues might be occurring. If we find any that will go to the Geoprocessing forum.
But the second issue 2) is the one that is really hurting us. When we load the new refreshed data using our process to ArcSDE using direct connect (as we have for years, like since ArcGIS 9.0 as SDE services, then direct connect) the views stopped working. In ArcCatalog or ArcMap it makes the views look like they are empty, or if they draw, you can't zoom in, out or pan because the features, if present disappear. We have tried rebuilding the spatial indexes, no change in behavior. We have tried recreating the views and relaoding them with our code (this test is still pending). I have done traces on the queries that get generated when you view a spatial view, and I can capture that the ArcSDE sp's that call, join etc the data show up in SQL Server. But the ArcGIS tools are not seeing them, or displaying them. As I am writing this, I am wondering if it is a client issue, but since we use both ArcGIS Server and ArcIMS I am trying to rule that out. Anyhow, it will be no small feat for us to have to recreate all of our Spatial Views across all of our data marts, especially if the next day's data load produces the same problem.
so I am wondering, has anyone seen this type of erratic behavior from ArcSDE/ArcGIS after upgrading to 10.1 with Spatial Views? What GDB changes were made that may have affected this?
So like I said before, we are SQL Server 2008 R2, ArcGIS 10.1 shop, and Python 2.7.
Joe
