I am trying to figure out how to get a count on each feature class in our SDE database and later record it to a text file but I am having trouble figuring out how to setup the "Get Count" portion of the script. I haven't had any success incorporating the "Get Count" example.
When "My Script" runs it prints the fc name (.e.g. jmillePCReplica.DBO.Wayne_Parcels) but when I plug that variable / fc name in place to the "Get Count" example it fails.
Any ideas?
My Script
<SPAN class="comment token"># Import system modules</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> os
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
<SPAN class="comment token"># Set workspace</SPAN>
sdeConnection <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"Database Connections\STR-DT-JMILLE.sde"</SPAN>
feature_classes <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
walk <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Walk<SPAN class="punctuation token">(</SPAN>sdeConnection<SPAN class="punctuation token">,</SPAN> datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">"FeatureClass"</SPAN><SPAN class="punctuation token">,</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">"All"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Starting.."</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> dirpath<SPAN class="punctuation token">,</SPAN> dirnames<SPAN class="punctuation token">,</SPAN> filenames <SPAN class="keyword token">in</SPAN> walk<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> filename <SPAN class="keyword token">in</SPAN> filenames<SPAN class="punctuation token">:</SPAN>
feature_classes<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>join<SPAN class="punctuation token">(</SPAN>dirpath<SPAN class="punctuation token">,</SPAN> filename<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Get Count Example
result <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{} has {} records'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> result<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>My Script results
Starting..
jmillePCReplica.DBO.P_AbandonedDevice
jmillePCReplica.DBO.P_AbandonedPipe
jmillePCReplica.DBO.P_AbandonedService
jmillePCReplica.DBO.P_AlignmentSheet
jmillePCReplica.DBO.P_CapitalProject
jmillePCReplica.DBO.P_Coupon
jmillePCReplica.DBO.P_CPArea
jmillePCReplica.DBO.P_DrinkingWater
jmillePCReplica.DBO.P_EcologicalArea
jmillePCReplica.DBO.P_ExcavationDamage
jmillePCReplica.DBO.P_ExposedPipeInspect
jmillePCReplica.DBO.P_GasLeak<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
