Im following the ESRI guide to running Arc Enterprise Builder to setup a base deployment for all the enterprise components(server, portal, web adapter, data store). However, When I run the builder everything works fine until it starts installing portal and then it get stuck on the progress bar about 1/4 of the way through the installation process. I let it continue running over night 12+hours and still it wont budge so I had to terminate the process in task manager. Strangely I see a directory for ArcGISportal full of application components,meta files and file dependencies but have no idea if it worked correctly. ArcServer is missing as well as the web adapter and Data Store. There are no error messages indicated in the installation process once it gets stuck. I've gone over the requirements checklist a dozen times to make sure we have all required ports open and memory/storage. At this point im totally lost as to why this seemingly routine installation wont finish correctly. Please Help!
