Anybody have any insight on why this is failing? (Line 62 below).
I am trying to update a text field using a DA Update Cursor. Please help!
File "\\bctsdata.bcgov\tsg_root\General_User_Workspace\Recce_Data\scripts\UploadPDFReports\UploadPDFReports.py", line 135, in <module>
UploadPDFReports(fcBlockPolygons, dirReceivedReports)
File "\\bctsdata.bcgov\tsg_root\General_User_Workspace\Recce_Data\scripts\UploadPDFReports\UploadPDFReports.py", line 105, in UploadPDFReports
cursor.updateRow(row)
RuntimeError: Object invalid or no longer set.
def GetOperArea_SpatialIntersect(fcOperArea, flds, shp):
fcOperArea = gp.MakeFeatureLayer_management(fcOperArea)
gp.SelectLayerByLocation_management(fcOperArea, "INTERSECT", shp )
with arcpy.da.SearchCursor(fcOperArea, flds) as cursor:
for row in cursor:
#gp.AddMessage("District:{0} OpArea:{1}".format(row[0], row[1]))
sDist = row[0]
sOp = row[1]
sBlkRepDir = os.path.join(sReportDir, sDist, sOp)
#gp.AddMessage(sBlkRepDir)
if os.path.exists(sBlkRepDir):
return sBlkRepDir
else:
os.makedirs(sBlkRepDir)
gp.AddMessage("**Need to create output directory:{}".format(sBlkRepDir))
return sBlkRepDir
def UploadPDFReports(fcRecceBlks, dirReports):
lstDist = []
startDir = sReportDir
#--Hardcoded field values that must exist
#--Block Polygon attributes
fldBlkName = "BLOCK_NAME"
fldLink = "FILE_LINK"
#--Operating Area attributes
fldDist = "MOF_DISTRI"
fldOpCode = "OP_AREA"
fldOpArea = "AREA_NAME"
#Loop through PDF Reports
#print dirReports
#gp.AddMessage(dirReports)
for dirpath, dirnames, filenames in os.walk(dirReports, True):
for file in filenames:
if "_RecceReport.pdf" in file:
sBlock = file.split("_")[0]
gp.AddMessage("Recce Report: " + sBlock)
#Loop through associated block spatial
iCnt = 0
exp = fldBlkName + " = '{0}'".format(sBlock)
gp.AddMessage(exp)
with arcpy.da.UpdateCursor(fcRecceBlks, ("SHAPE@XY", fldLink), where_clause=exp) as cursor:
for row in cursor:
#--Get the centroid of the polygon. Use the polygon centroid to determine which Op Area it's in
pnt = row[0]
shp = arcpy.Point()
shp.X = pnt[0]
shp.Y = pnt[1]
gp.AddMessage(row[1])
sCurrLink = NzStr(row[1])
pntGeom = arcpy.PointGeometry(shp)
#--Get the directory to store the report based on the spatial operating area
#lyrOpArea = gp.MakeFeatureLayer_management(fcOpArea)
sBlkRepDir = GetOperArea_SpatialIntersect(fcOpArea, (fldDist, fldOpArea), pntGeom)
sLink = os.path.join(sReportDir, sBlkRepDir, file)
gp.AddMessage("*{0}".format(sLink))
row[1] = sLink
