Just wanted to make people aware of an issue with the 3.14 api and Street View
The 3.14 api introduces a new css element in esri.css
.map .container .layersDiv > div {
pointer-events: none;
}This breaks google street view if you have it embedded in your map div as a child, as it uses pointer-elements
As a workaround, when street view is visible, loop through the elements and turn pointer-events on
array.forEach(query('.map .container .layersDiv > div'), function(node){
domStyle.set(node, 'pointerEvents', 'auto');
});and then when you close street view, turn them back off
domStyle.set(node, 'pointerEvents', 'none');
