I have a esri.InfoTemplate that calls a function. Within the function I am setting content of a dojox.layout.ContentPane. I am utilizing a dojox content pane because I need a piece of javascript code to execute. Eventually I need to get a reference to a node within the dojox.layout.ContentPane, whether that node was part of the content or dynamically created. The problems is that I cannot get a reference to a node within the ContentPane in IE 8. The code works fine in FF, Safari, and Chrome.My question is, is there a way to get a reference to a node in the content pane in IE 8 utilizing the code below? Entire Process:1. identify feature2. process the identified features by attaching script as a feature attribute3. set feature info template to a function4. function creates a dojox.layout.ContentPane5. function retrieves script from feature6. function sets script/node as the content7. returns content pane domNode to feature8. if all goes correctly, a video plays within the popup windowBelow is simplified code to illustrate the problem in IE 8. //called by maptip each time the maptip record selector moves to that graphic function getLiveViewContent(graphic) { var cpX = new dojox.layout.ContentPane({id:"videoContainer"}); //the node is part of the content of the contentpane but when the content is set, IE 8 cannot find the node var videoNode1 = "<div id='videoNode1'>Loading.....</div><scr" + "ipt type='text/javascript'> var cnNode;var vidNode; var i=0;function checkContainter(){while(cnNode==null&&i<50){cnNode = dijit.byId('videoContainer');if (cnNode!=null){console.log('got cnNode');}i++;}}checkContainter();i=0;function checkVideoNode(){while(vidNode==null&&i<50){vidNode = dojo.byId('videoNode1');i++;console.log(i);if (vidNode!=null){console.log('got vidNode');}}}checkVideoNode();console.log('done');<\/scr" + "ipt>"; //this code retrieves an already created node within the document and appends that node to the container node. In IE 8, after the append the dojo.byID('videodiv') is null var videoNode2 = "<scr" + "ipt type='text/javascript'> var cnNode;var vidNode; var i=0;function checkContainter(){while(cnNode==null&&i<50){cnNode = dijit.byId('videoContainer');if (cnNode!=null){console.log('got cnNode');vidNode = dojo.byId('videodiv');if (vidNode!=null){console.log('got vidNode');}cnNode.containerNode.appendChild(vidNode);}i++;}}checkContainter();i=0;var checkNode;function checkVideoNode(){while(checkNode==null&&i<50){checkNode = dojo.byId('videodiv');i++;console.log(i);}}checkVideoNode();console.log('done');<\/scr" + "ipt>"; //var data = graphic.attributes.liveviewdata; //data = data.replace("jwplayer",videoNode); cpX.set("content", videoNode2); return cpX.domNode; } identifiedFeatures.addCallback(function(response) { return dojo.map(response, function(result) { var feature = result.feature; //console.log(feature); if(feature.attributes.liveviewdata!=null && feature.attributes.liveviewdata!="" ){ var template = new esri.InfoTemplate("",getLiveViewContent); feature.setInfoTemplate(template); } return feature; }); }); map.infoWindow.setFeatures([ identifiedFeatures ]); map.infoWindow.show(evt.mapPoint); }
