Hi, i am attempting to print a map with a csv layer with custom unique value renderer (picture marker symbols)when i have this layer in the map, the print dijit fails, in Chrome logging SyntaxError: Unexpected token < at Object.b.fromJson (http://js.arcgis.com/3.9/init.js:226:310)
When i remove the CSV layer, it prints out fine.here is the code in its entirety.
CSVpath = "http://astro.ngacres.com/htmlemails/master/master/lburbank.csv";
request(CSVpath).then(function(data){
lines = data.split(/\r?\n/);
var popup = new Popup({
popupWindow: true
}, domConstruct.create("div"));
var csvTemplate = new PopupTemplate({
title: "{name}", //wrap field names in {}
fieldInfos: [
fieldName: "address", //acutal field name in the file
visible: true,
label: "Address: " //what shows in the popup box
fieldName: "city",
visible: true,
label: "City: "
fieldName: "state",
visible: true,
label: "State: "
fieldName: "zipcode",
visible: true,
label: "Zip Code: "
fieldName: "county",
visible: true,
label: "County: "
fieldName: "psf",
visible: true,
label: "Price per Square Foot: "
fieldName: "acres",
visible: true,
label: "Acreage: "
fieldName: "parcel_id",
visible: true,
label: "Parcel Number: "
map = new Map("mapDiv", {
basemap: "hybrid",
center: [-111.98868856152143, 40.76044344742585], // long, lat
zoom: 14, //the smaller the number, the farther it zooms out
infoWindow: popup, //reference to the popup object we made
logo: false, //hide esri logo
minZoom: 3 ,//farthest we can zoom out
wrapAround180: true, //continuous scrolling
slider: true
map.attribution.destroy()
csv = new CSVLayer(CSVpath, {
copyright: "Acres Companies",
csv.setInfoTemplate(csvTemplate);
var i = 1;
var orderNums = []
while(i<100){
orderNums.push(i)
i++
map.on("load", addRenderRules); //When the map is done loading, add some rendering rules to the CSV Layer with a function called 'addRenderRules'
function addRenderRules() {
var defaultSymbol = null; //if there is a feature that doesnt match the 'Order' rules, it will not draw
//create renderer and rules
var renderer = new UniqueValueRenderer(defaultSymbol, "order"); //Create the renderer based on the 'Order' field
//add symbol for each value 1-99
for (var n=0;n<orderNums.length;n++){
renderer.addValue(orderNums, new PictureMarkerSymbol('http://astro.ngacres.com/htmlemails/interactive/images/'+orderNums+'.png', 25, 25)) //variable URL to icon images, width, height
csv.setRenderer(renderer); //apply the render rules to the CSV layer
//ESRI roads layer
var Transportation = new Tiled("http://services.arcgisonline.com/arcgis/rest/services/Reference/World_Transportation/MapServer",{
var items = []; //placeholder to count the items added to the legend
//once the layers has been added, build the legend by referencing the CSV file
map.on("layers-add-result",function(){
var headers = lines[0].split(',');
var otherData = lines.splice(1);
array.map(headers, function(header){ ///get the header fields from the CSV File
return {
field: header,
array.map(otherData, function(line){ //Match the subsequent fields to their headers
var cells = line.split(','), obj = {};
array.forEach(cells, function(cell, idx){
obj[headers[idx]] = cell;
if (obj.name !== undefined) { //All valid data added one by one to the legend
items.push(obj.order)
document.getElementById("legendDiv").innerHTML += "<img src=http://astro.ngacres.com/htmlemails/interactive/images/" + obj.order + ".png style='width:20px;height:20px;vertical-align:middle'> " + "<a href='javascript: void(0)' id='button"+obj.order+"'>" + obj.name + "</a><br/>"
return obj
array.forEach(items, function(id){ //Click on legend to pan to feature
document.getElementById('button' + id).onclick = function(me){
var buttonID = me.srcElement.id.replace(/[A-Za-z]/g,"");
array.forEach(map.getLayer("CSV").graphics, function(item){
if (item.attributes.order === buttonID){
map.centerAt([item.attributes.longitude,item.attributes.latitude]);
printer = new Print({
map: map,
templates: [{
label: "Letter Portrait",
format: "PDF",
layout: "Letter ANSI A Portrait",
preserveScale: false,
exportOptions: {
dpi: 300
showAttribution: false
label: "Letter Landscape",
format: "PDF",
layout: "Letter ANSI A Landscape",
exportOptions: {
dpi: 300
url: "http://maphics:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task"
}, dom.byId("printButton"));
printer.startup();
map.addLayers([csv,Transportation]); //add the layers to the map
How can i get the print dijit working with my CSV layer in the map?Any help would be much appreciated!!!
