Hi Guys,
i have some JSON data and wantto display it on map, but i cant.
what i do wrong?
<SPAN class="keyword token">var</SPAN> flayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
objectIdFieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
globalIdFieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
geometryType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"point"</SPAN><SPAN class="punctuation token">,</SPAN>
fields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"oid"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Wis_kam_ID"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Wis_kameris_ID"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"string"</SPAN><SPAN class="punctuation token">,</SPAN>
length<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">12</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"nomeri_planSetze"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"nomeri_planSetze"</SPAN><SPAN class="punctuation token">,</SPAN>
length<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
features<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">477262.23610000033</SPAN><SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4637311.2296999991</SPAN>
attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
OBJECTID<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
Wis_kam_ID<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"WA-AR-1"</SPAN><SPAN class="punctuation token">,</SPAN>
nomeri_planSetze<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>flayer<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
