I am attempting to merge this sample into an existing script where I am using the identify tool and making selections etc.
Show find task results in a DataGrid | ArcGIS API for JavaScript
https://developers.arcgis.com/javascript/jssamples/find_map_datagrid.html
The sample has a search for parcel functionality that is just what I want though I'm adapting it to search for roads in a street centerlines layer.
Chrome's javascript console tells me this which is one clue
Cannot read property 'on' of undefined
Where I'm getting this is on this line here
registry.byId("search").on("click", doFind);
Which is exactly how it is used in the sample. Here is how the "require" part starts out ... I also have a button control with the id "search" just as in the sample I linked to above (see html code posted below the require code). Can anyone see where I could be going wrong ?
when the line of code above registry.byId ... is NOT commented out, the html bit below goes away. When I comment it out, I see the search control and the table.
I also tried other methods to "connect" the click event to the search button but they don't work either. I have all the other code from the sample in there (such as the doFind function) which should run when the button is clicked.
Any ideas why this is not working ?
<code>
| <script src="http://js.arcgis.com/3.9/"></script> |
| <script> |
| var findTask, findParams; // * |
| var map, center, zoom; // * center and zoom are new |
| var grid, store; // * |
| var identifyTask, identifyParams; |
| require([ |
| | "esri/map", |
| | "esri/dijit/BasemapGallery", |
| | "esri/dijit/Popup", |
| | "esri/layers/ArcGISDynamicMapServiceLayer", |
| | "esri/tasks/query", |
| | "esri/toolbars/draw", |
| | "esri/tasks/IdentifyTask", |
| | "esri/tasks/FindTask", |
| | "esri/tasks/FindParameters", |
| | "esri/layers/FeatureLayer", |
| | "esri/tasks/IdentifyResult", |
| | "esri/tasks/IdentifyParameters", |
| | "esri/dijit/InfoWindow", |
| | "esri/symbols/SimpleFillSymbol", |
| | "esri/symbols/SimpleLineSymbol", |
| | "esri/InfoTemplate", |
| | "dojo/_base/array", |
| | "dojo/_base/Color", |
| | "dojo/dom", |
| | "dojo/on", |
| | "dijit/registry", |
| | "dojo/parser", |
| | "dijit/layout/BorderContainer", |
| | "dijit/layout/ContentPane", |
| | "dijit/TitlePane", |
| | "dijit/form/Button", |
| | "dijit/form/RadioButton", |
| | // "dojo/parser", |
| | "dojo/domReady!" |
| | ], function(Map, BasemapGallery, Popup, ArcGISDynamicMapServiceLayer, Query, Draw, IdentifyTask, FindTask, FindParameters, FeatureLayer, IdentifyResult, IdentifyParameters, InfoWindow, |
| | SimpleFillSymbol, SimpleLineSymbol, InfoTemplate, arrayUtil, Color, dom, on, registry, parser, BorderContainer, ContentPane, TitlePane, Button, RadioButton) { |
| | //setup the popup window |
| | parser.parse(); |
| | registry.byId("search").on("click", doFind); |
| | // on(dom.byId("search"), "click", doFind); |
| | // mapOnLoad = dojo.connect("search", "click", doFind); |
</code>
<code>
| <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:190px;"> |
| | <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="height:30px; margin-top: 0;"> |
| | Road name: <input type="text" id="ownerName" size="60" value="ROCK LODGE RD" /> | |
| | <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search | |
| | </button> |
| | </div> |
| | <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'15', rowSelector:'20px'"> |
| | <thead> |
| | <tr> |
| | <!--<th field="PARCELID">Parcel ID</th>--> |
| | <th field="STREET_ALL">NAME</th> |
| | <!--<th field="OWNERNME1" >Owner 1</th>--> |
| | <th width="120px" field="MAINTENANCE">MAINTENANCE</th> |
| | <!--<th field="OWNERNME2">Owner 2</th>--> |
| | <th field="FROM_LEFT_P" >FROM LEFT</th> |
| | <th field="TO_LEFT_P">TO LEFT</th> |
| | <th width="130px" field="FROM_RIGHT_P">FROM RIGHT</th> |
| | <th field="TO_RIGHT_P">TO RIGHT</th> |
| | <!--<th field="RESYRBLT ">Year Built</th>--? |
| | <!--<th field="SITEADDRESS" width="100%">Address</th>--> |
| | </tr> |
| | </thead> |
| </table> |
| </div> |
</code>
