Sql server Enterprise DB 10.2.2
ArcServer 10.2.2
Feature class has versioning enabled, archiving enabled, GlobalID, Attachments enabled
I don't need offline
Published service with feature access - Create,Delete,Query,Update,Uploads,Editing - Layer: Triennial Inspections (ID: 0)
Service is published in MD State Plane NAD 83 feet.
Service was registered with Arcgis Online - Map and layer are shared with the same settings. This is the only layer in the map other than the esri basemap.
The service works/edits just fine in online map. popups configured
Yes my device can see the rest-endpoint
Issue: In collector I can see the map but the layer will not draw. I can't toggle it on.
What am I missing?
