Greetings all -
I remember attending a session at the UC about how to setup the Web Adaptor (IIS) to run as a fail over between multiple ArcGIS servers. Essentially what I would like to setup is a routine where the end user clicks on a Flex Viewer link and is served the data from Server A. If after lets say 15 seconds there is no response from Server A (it is down, or has a problem) Server B is automatically loaded. I would only like this to happen at the initial load of the viewer and not for every request. How difficult would it be to set this up, and integrate with Portal on a local Intranet? I will post a question about syncing everything separately as I just want to get the fail over setup before scripting all the syncing together.
Thanks in advance for the help!
