Hi all,
I have a problem with touching my points in the map. The problem occurs in all sample codes from esri I tested (for example Reference Arcade expressions in PopupTemplate | ArcGIS API for JavaScript 4.4 ). I want to open a popUp of a point object but when touching it with my finger/with a pen, the map shifts a bit. It shifts just a little bit despite concentrating on doing a "steady" touch movement. Doing 4-5 concentrated touches, the popUp opens sometimes. Working outdoor makes it additionally difficult.
This problem just occurs on the Samsung Tab Active!!! On all other tested smartphones/pc with mouse there is no problem. I already searched in android settings of the device to lower touch sensitivity but found nothing.
Is there any possibility to lower the touch sensitivity of the map itself?
