I am new to javascript, but I am trying to put together a fairly simple application with v4.6. I have a contour layer that I am adding with new FeatureLayer(), but I am having a hard time getting it to label with elevation. I have tried using a Map Service hosted on our server, as well as, a hosted Feature Layer on AGOL (where the contours are already labeled in both). No luck with either. I have read that you can't label a 2D map, does this mean that it is virtually impossible to label the contours?? Is there any work around? A label would be so much better than a pop-up. Thanks for the help.
