I've been writing Python scripts for a while now, and when a colleague of mine viewed my code, he cringed that it wasn't structured into Python Functions. I'd like some advice from the ESRI community in how I could structure my Python scripts into functions\modules that will make it easier to reuse and call within new scripts. I've attached one of my Python scripts that uses ArcPy and ArcHydro Functions.
Created on May 20, 2015
author: PeterW
# import system modules and site packages
import os
import arcpy
import ArcHydroTools
# check out Spatial Analyst Extension
# set environment settings
# set input and output arguments
raw = r"F:\Projects\2015\G111443\ArcHydro\Methodology_Models\Section03\Sect3A\DEM04\raw"
rasWs = r"F:\Projects\2015\G111443\ArcHydro\Methodology_Models\Section03\Sect3A\Layers04"
outWs = r"F:\Projects\2015\G111443\ArcHydro\Methodology_Models\Section03\Sect3A\Model04.gdb"
# ArcHydro variables
fill_sinks = os.path.join(rasWs, "fil")
flow_dir = os.path.join(rasWs, "fdr")
flow_acc = os.path.join(rasWs, "fac")
streams = os.path.join(rasWs, "str")
stream_seg = os.path.join(rasWs, "strlnk")
catchment_grid = os.path.join(rasWs, "cat")
catchment_poly = os.path.join(outWs, "Layers","Catchment")
drainage_line = os.path.join(outWs, "Layers", "DrainageLine")
adj_catch = os.path.join(outWs, "Layers", "AdjointCatchment")
try:
# calculate the fill sinks
arcpy.AddMessage("Processing Fill Sinks")
ArcHydroTools.FillSinks(raw, fill_sinks)
# calculate the flow direction
arcpy.AddMessage("Processing Flow Direction")
ArcHydroTools.FlowDirection(fill_sinks, flow_dir)
# calculate the flow accumulation
arcpy.AddMessage("Processing Flow Accumulation")
ArcHydroTools.FlowAccumulation(flow_dir, flow_acc)
# calculate the maximum flow accumulation
arcpy.AddMessage("Processing Flow Accumulation Maximum")
maxcellsResult = arcpy.GetRasterProperties_management(flow_acc, "MAXIMUM")
maxcells = maxcellsResult.getOutput(0)
print maxcells
# calculate the stream threshold number of cells
arcpy.AddMessage("Processing Stream Threshold")
stream_threshold_numcells = (int(maxcells)*0.25/100)
print stream_threshold_numcells
# calculate the stream definition
arcpy.AddMessage("Processing Stream Definition")
ArcHydroTools.StreamDefinition(flow_acc, stream_threshold_numcells, streams)
# calculate the stream segmentation
arcpy.AddMessage("Processing Stream Segmentation")
ArcHydroTools.StreamSegmentation(streams, flow_dir, stream_seg)
# calculate the catchment grid delineation
arcpy.AddMessage("Processing Catchment Grid Delineation")
ArcHydroTools.CatchmentGridDelineation(flow_dir, stream_seg, catchment_grid)
# calculate the catchment polygons from the catchment grid
arcpy.AddMessage("Processing Catchment Polygons")
ArcHydroTools.CatchmentPolyProcessing(catchment_grid, catchment_poly)
# calculate the drainage lines from the stream segmentation grid
arcpy.AddMessage("Processing DrainageLines")
ArcHydroTools.DrainageLineProcessing(stream_seg, flow_dir, drainage_line)
# calculate the adjoint catchment polygons
arcpy.AddMessage("Processing Ajdoint Catchments")
ArcHydroTools.AdjointCatchment(drainage_line, catchment_poly, adj_catch)
arcpy.AddMessage("Completed Processing ArcHydro Main Model")
except:
print(arcpy.GetMessages(2))
pass
arcpy.CheckInExtension("Spatial")Any advice and assistance will be appreciated.
Regards
Peter Wilson
