I am trying to display a popup based on the identify module. For some reason, my identify task is not returning results. Here is the code:
executeIdentifyTask: function (evt) {
this.previewMode = false;
this.map.infoWindow.hide();
this.map.infoWindow.clearFeatures();
// don't identify on shift-click, ctrl-click or alt-click
if (evt.shiftKey || evt.ctrlKey || evt.altKey) {
return;
var mapPoint = evt.mapPoint;
var identifyParams = this.createIdentifyParams(mapPoint);
var identifies = [];
var identifiedlayers = [];
var selectedLayer = this.getSelectedLayer();
array.forEach(this.layers, lang.hitch(this, function (layer) {
var layerIds = this.getLayerIds(layer, selectedLayer);
if (layerIds.length > 0) {
var params = lang.clone(identifyParams);
params.layerDefinitions = layer.ref.layerDefinitions;
params.layerIds = layerIds;
identifies.push(layer.identifyTask.execute(params));
identifiedlayers.push(layer);
if (identifies.length > 0) {
this.map.infoWindow.setTitle(this.i18n.mapInfoWindow.identifyingTitle);
this.map.infoWindow.setContent('<div class="loading"></div>');
all(identifies).then(lang.hitch(this, 'identifyCallback', identifiedlayers, mapPoint), lang.hitch(this, 'identifyError'));
} else {
this.previewMode = true;
