Hi guys,
I am trying to use Collector and related tables in the following way:
I have two Feature Classe: EQUIPEMENTS LEVEL 1 (suppose EQ1_A and EQ1_B) and one EQUIPEMENT LEVEL 2 (a table, not a Feature Class), let's call this one EQ2
I need to relate both EQ1_A and EQ1_B to EQ2 with a 1:M Relationship Class.
I created GLOBALID in EQ1_A and EQ1_B.
I created a GUID Field in EQ2
I created both the relationship classes (origin: EQ1_A and EQ1_B - destination EQ2 - primary key GLOBALID - foreign key GUID Field).
I published the map with EQ1_A, EQ1_B and EQ2 with ArcGIS Server 10.5.1
I created my map in Portal with all the three classes in the TOC.
I enabled PopUps
I consumed the map with Collector.
I can see the relationship only for EQ1_A and not for EQ1_B.
Then I tried to create two different Feature Services one with EQ1_A and EQ2 in the TOC, and the other one with EQ1_B and EQ2.
I composed the map with the two different Feature Layers and I am able to see both the relationships.
Is that the right way to manage a table related to multiple Feature Classes/Object Classes in Collecotr? I couldn't find documentation about this particular situation.
Regards
