Dear all,
I have a problem publishing an Image or whatever service from a mosaic dataset. We are running ArcGIS Server 10.5 and 10.6. The client I use for publishing is ArcMap 10.7. So what I do is as follows:
1. I create the mosaic dataset in an empty File Geodatabase.
2. I add the rasters to the database and compute all the statistics and pyramids and overviews.
3. I say share as Image service and leave everything as is. No error sanalyzing and preview looks fine.
4. The service is created, but I get the massage that there is an invalid source path with there definitley is NOT.
Datasource is registered and we have all the necessary licenses.
Did this a couple of times before and everything went smoothly, now this.....I already contacted the ESRI support but as it is urgent I am also looking for any help here. I heard, that there is a similiar error using ArcGIS Pro 2.3 but the ESRI advised solution there is to ues ArcMAP. This is a bad joke in my opinion if it is a bug.
Thanks for any help.
Andreas
