So, I am migrating code from 9.3 to 10.1 SP1.The code is working on 9.3, but not on 10.1 SP1After long fight I narrow the problem to this.In 10.1 I cannot do intersection between two polylines to produce third polyline.Is that correct?I wrote below very simple Visual Studio console application that is doing intersection between two polylines.I created very two simple polylines, using WKT library , which you can get it from here.Anyway you can replace it with any code that generate simple polylines. static void Main(string[] args)
//ESRI License Initializer generated code.
m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeStandard, esriLicenseProductCode.esriLicenseProductCodeAdvanced },
new esriLicenseExtensionCode[] { });
var geom1 = "LINESTRING (2 1, 7 1)".ToGeometry();
var geom2 = "LINESTRING (3 1, 6 1)".ToGeometry();
var targetOperator = (ITopologicalOperator)geom1;
targetOperator.Simplify();
IGeometry intersectGeometry = targetOperator.Intersect(geom2, esriGeometryDimension.esriGeometryNoDimension );
Console.WriteLine(intersectGeometry.ToWellKnownText());
m_AOLicenseInitializer.ShutdownApplication();
The above code generate this COM ExceptionError HRESULT E_FAIL has been returned from a call to a COM component.With error code-2147467259
