I've downloaded and extracted the latest version of WAB but when I run startup.bat I get the following error:
fs.js:653
return binding.mkdir(pathModule._makeLong(path),
Error: EPERM, operation not permitted 'C:\Program Files\WebAppBuilderForArcGIS\server\logs'
at Object.fs.mkdirSync (fs.js:653:18)
at Object.<anonymous> (C:\Program Files\WebAppBuilderForArcGIS\server\server.js:73:6)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
at startup (node.js:119:16)
at node.js:906:3
Press any key to continue . . .
I thought maybe it was a permissions problem so I ran startup.bat as an administrator and now I simply get the error:
"server" directory does not exist
The server directory definitely exists. It contains 17 files and 3 directories. I've deleted everything and downloaded a fresh copy but still get the same error. Node.js is installed from a previous version of WAB.
Ideas?
Thanks!
Jill
