Hi all,I am trying to have one-button push to activate three different functions independently. Thre three functions are:1st function: Extratct data per graphics2nd function: extract data per query (county)3rd function: extract data per query (unit)The idea is that I would use a switch... case statements and have a global variable that allows users to overwrite the value as such. on(dom.byId("sel_county"), "onChange", function () { extractMethod = "extractByCounty"; console.log("You are selecting a county!"); }); on(dom.byId("sel_unit"), "onChange", function () { extractMethod = "extractByUnit"; console.log("You are selecting a unit!"); }); function initSelectionToolbar() { map.graphics.clear(); selectionToolbar = new Draw(map); selectionToolbar.on("draw-end", function (e) { selectionToolbar.deactivate(); var symbol3 = new SimpleFillSymbol( "solid", new SimpleLineSymbol("dash", new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]) ); var graphic = new Graphic(e.geometry, symbol3); map.graphics.add(graphic); extractMethod = "extractByPoly"; }); } function activateTool(tool) { map.graphics.clear(); // The draw.activate expects a string like "polygon" or "freehand_polygon". selectionToolbar.activate(tool); } function myFunction() { //var extractMethod = "extractByPoly"; //var extractMethod = "extractByCounty"; //var extractMethod = "extractByUnit"; switch (extractMethod) { default: //function extractData() { //get clip layers var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0 || map.graphics.graphics.length === 0) { alert("Select layers to extract and draw an area of interest."); return; } var featureSet = new FeatureSet(); var features = []; features.push(map.graphics.graphics[0]); featureSet.features = features; var params3 = { "Layers_to_Clip": clipLayers, "Area_of_Interest": featureSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading2, "display", "inline-block"); gp.submitJob(params3, completeCallback, statusCallback2, function (error) { alert(error); domStyle.set(loading2, "display", "none"); }); //} break; case "extractByCounty": //function executeQueryTask(county) { var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0) { alert("No layers to clip, please select a layer you would like to clip..."); return; } var county = document.getElementById("sel_county").value var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Counties/MapServer/0"); var query = new Query(); query.returnGeometry = true; query.outFields = ["NAME_PCASE"]; query.where = "NAME_PCASE = '" + extractMethod + "'"; query.outSpatialReference = map.spatialReference; queryTask.execute(query, function (featureSet) { if (featureSet.features.length === 0) { alert("Query task did not return any features"); return; } else { var AOI = featureSet.features[0].geometry; var graphic = new Graphic(AOI, symbol); var features = []; features.push(graphic); var fSet = new FeatureSet(); fSet.features = features; var params = { "Layers_to_Clip": clipLayers, "Area_of_Interest": fSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading, "display", "inline-block"); gp.submitJob(params, completeCallback, statusCallback, function (error) { alert(error); domStyle.set(loading, "display", "none"); }); } }); //} break; The default in the switch statement works normally. However, the two other statemnets dont work because the Javascript listener do not fire up correctly.on(dom.byId("sel_county"), "onChange", function () { extractMethod = "extractByCounty"; console.log("You are selecting a county!"); }); on(dom.byId("sel_unit"), "onChange", function () { extractMethod = "extractByUnit"; console.log("You are selecting a unit!"); });Any ideas how to make the listeners fire up?
