Hi everyone
I try to show all results of several layers immediately in an InfoWindow without navigating over the arrow in the top right corner of InfoWindow (next / previous feature layer). Is that possible?
As a test, I use the following example
<!DOCTYPE html>
<html>
<head>
<title>Identify with Popup</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
<style>
html, body, #map {
height:100%;
width:100%;
margin:0;
padding:0;
</style>
<script src="https://js.arcgis.com/3.27/"></script>
<script>
var map;
require([
"esri/map",
"esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/tasks/IdentifyTask",
"esri/tasks/IdentifyParameters",
"esri/dijit/Popup",
"dojo/_base/array",
"esri/Color",
"dojo/dom-construct",
"dojo/domReady!"
], function (
Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol,
SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup,
arrayUtils, Color, domConstruct
var identifyTask, identifyParams;
var popup = new Popup({
fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
}, domConstruct.create("div"));
map = new Map("map", {
basemap: "satellite",
center: [-83.275, 42.573],
zoom: 18,
infoWindow: popup
map.on("load", mapReady);
var parcelsURL = "https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer";
map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,
{ opacity: 0.55 }));
function mapReady () {
map.on("click", executeIdentifyTask);
//create identify tasks and setup parameters
identifyTask = new IdentifyTask(parcelsURL);
identifyParams = new IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [0, 2];
identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
identifyParams.width = map.width;
identifyParams.height = map.height;
function executeIdentifyTask (event) {
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
var deferred = identifyTask
.execute(identifyParams)
.addCallback(function (response) {
// response is an array of identify result objects
// Let's return an array of features.
return arrayUtils.map(response, function (result) {
var feature = result.feature;
var layerName = result.layerName;
feature.attributes.layerName = layerName;
if (layerName === 'Tax Parcels') {
var taxParcelTemplate = new InfoTemplate("",
"${Postal Address} <br/> Owner of record: ${First Owner Name}");
feature.setInfoTemplate(taxParcelTemplate);
else if (layerName === 'Building Footprints') {
console.log(feature.attributes.PARCELID);
var buildingFootprintTemplate = new InfoTemplate("",
"Parcel ID: ${PARCELID}");
feature.setInfoTemplate(buildingFootprintTemplate);
return feature;
// InfoWindow expects an array of features from each deferred
// object that you pass. If the response from the task execution
// above is not an array of features, then you need to add a callback
// like the one above to post-process the response and return an
// array of features.
map.infoWindow.setFeatures([deferred]);
map.infoWindow.show(event.mapPoint);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
Thanks in advance
