I have some code. It is normally is OK in Chrome
It was flaky in IE10. The chunk that didn't work checked to see if a URL parameter was passed, if so, it set a query layer, used the passed parameter for a query task, got the extent of the query results and set map extent to it.
I had it all in my general init function. Most times in IE it would fail to re-draw the map. However a slight pan would put the map in the correct place (plus the slight pan of course)
I moved this code into the onLayersAddResult event of the map.
In IE it works a lot better,but still fails about 10% of the time.
Are any events after onLayersAddResult I can hook up to? Or any other tricks to get my timing right?
Cheers
ACM
