Dear All,
is possible to check the signIn status in the portal?
A lot of example uses the default Dialog Box for the login.
I created a custom qml for the login.
How is it possible to check if the login are going successfully or not?
import QtQuick 2.3
import QtQuick.Controls 2.0
import Esri.ArcGISRuntime 100.0
ApplicationWindow { id: appWindow
width: 800
height: 600
title: "TestMapQtNEW"
Frame { id: frmLogin
x: 203
y: 200
width: 394
height: 200
anchors.verticalCenter: parent.verticalCenter
anchors.horizontalCenterOffset: 0
anchors.horizontalCenter: parent.horizontalCenter
opacity: 1
clip: false
Label { id: lblPassword
x: 53
y: 80
text: qsTr("Password:") }
Label { id: lblUsername
x: 53
y: 49
text: qsTr("Username:") }
TextField { id: txtPassword
x: 132
y: 74
placeholderText: qsTr("Text Field") }
TextField { id: txtUsername
x: 132
y: 43
Portal { id: myPortal
url: "http://www.arcgis.com"
Button { id: btnLogin
x: 232
y: 125
text: qsTr("Login") onClicked: {
var credential = ArcGISRuntimeEnvironment.createObject("Credential", {username:txtUsername.text, password:txtPassword.text}); myPortal.credential = credential;
myPortal.signIn();
//AND NOW? HOW I CAN CHECK THE STATUS AND/OR THE ERROR?
// add a mapView component
