I am using Esri Javascript API 4.6Is it possible to Assign an elevation at the end of spider lines- from my store point elevation (total Count). or how to curve them as Figure one is what I have so far, when clicked on any store it show a flat spider line (feature Class with definition expression).Figure 2 is what I need to accomplish.
Solved by Using Construct Line of sight, and assigning 0 to the elevation in the target field solved it.
Did you pre-calculate the elevation in ArcGIS Pro and then published the lines? I guess you can also do that client-side by manipulating the z values in the polyline geometry, but it's probably better to save the computation for something else if they have values that never change.
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
