Anyone have a good example of a sample that uses the Export Web Map task but allows the users the ability to select if they want to do pdf/jpeg etc .. Having trouble finding anything like that.Also if I am using this service on the same web server as my arcgis server behind our firewall (big company) do I need to worry about proxy server? I can use this service with the Flex API without having to worry about proxy server stuff. Getting these errors though. Do I need to require anything. I require - "esri/dijit/Print"LOG: esri.config.defaults.io.proxyUrl is not set. LOG: Error: esri.config.defaults.io.proxyUrl is not set. Error: esri.config.defaults.io.proxyUrl is not set. SCRIPT5022: No region setting for fpMeasurement I thought this would work:
function Print(){
alert("Found Printing Start");
var printUrl = "http://myserver:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
//REST URL: http://myserver:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer
//SOAP URL: http://myserver:6080/arcgis/services/Utilities/PrintingTools/GPServer
//Set up print stuff
var printTask = new esri.tasks.PrintTask(printUrl);
var params = new esri.tasks.PrintParameters();
var template = new esri.tasks.PrintTemplate();
params.map = map;
alert("Found Mark 1");
template.exportOptions = {
width: 595,
height: 842,
dpi: 96
template.format = "PDF"
template.layout = "Letter ANSI A Landscape";
template.preserveScale = false;
alert("Found Mark 2");
params.template = template;
alert("Found Mark 3");
//dojo.connect(map, "onLoad", function() {//Fire the print task
printTask.execute(params, printResult, printError);
setTimeout(function(){printTask.execute(params, printResult, printError);},2500);
alert("Found Mark 4");
function printResult(result){
console.log(result.url)
function printError(result){
console.log(result);
