Ok, I have the following python script which migrates and maps fields and the values of those fields into a target Feature Class. # Import arcpy module import arcpy arcpy.env.workspace = "G:\ChrisGIS\WDFW_NWIFC_EVENT_17100101.gdb" arcpy.env.overwriteOutput = "True" def GetFieldMappings(inputFC, targetFC, dico): field_mappings = arcpy.FieldMappings() field_mappings.addTable(inputFC) for input, output in dico.iteritems(): field_map = arcpy.FieldMap() field_map.addInputField(inputFC, input) field = field_map.outputField field.name = output field_map.outputField = field field_mappings.addFieldMap(field_map) del field, field_map return field_mappings #Variables inputFC = "WDFW_CHFA_2HEM_evt_1" targetFC = "WDFW_CHFA_2HEM_evt_olay_1" dico = {'Permanent_Identifier': 'Permanent_ID', 'STRM_NAME': 'LLID_STRM_NAME', 'DATE_SRVY': 'SOURCE_DATE', 'SPPCODE': 'SPECRCODE', 'SRC_AGENCY': 'SOURCE_AGENCY', 'SRC_WHO': 'SOURCE_WHO'} Mapper = GetFieldMappings(inputFC, targetFC, dico) # Process: Append arcpy.Append_management(arcpy.env.workspace+"\\"+inputFC, arcpy.env.workspace+"\\"+targetFC,"NO_TEST",Mapper)I have several feature classes to run this script on. AN exmaple of the Feature Classes that I need to run my script on are :WDFW_CCT_2HEM_evt_olayWDFW_CHFA_2HEM_evt_olayWDFW_CHMF_2HEM_evt_olayWDFW_CHSP_2HEM_evt_olayWDFW_CHSU_2HEM_evt_olayWDFW_COHO_2HEM_evt_olayWDFW_DBT_2HEM_evt_olayWDFW_KOK_2HEM_evt_olayWDFW_RBT_2HEM_evt_olayWDFW_SOCK_2HEM_evt_olayThese feature classes are represented in several geodatabases (see image)[ATTACH=CONFIG]20670[/ATTACH]I could simply go to each individual geodatabase and run the script for each featureclass in that geodatabase. This however seems redundant and I would like to figure out how to batch my scrip or automate this process. All geodatabases are located in one working directory.I appreciate any help or advice!
