Good day,
I'm using an external Toolbox in my current analysis. One of the inputs has to be a short integer grid, containing values of "0" and "1". But the field type of the Raster I currently have (Tif-Format) is a long integer. I already tried to add a short integer field in the attribute table and used the field calculation. But the Input raster for the toolbox can not have another column then the short integer value. If I use the tool "delete field" to delete the long integer field, the geographical information gets lost, as this is the main value field. Do you know how I can convert the long into short integer values, od how can I create a new raster with short integer values?
Thanks in advance,
Jonas
