I am trying to delete duplicates form a table but the issues is the part where I try to delete the duplicates.
The script merges table together then delete the duplicates. After the script runs i noticed that there were still duplicates so i ran just the delete duplicates part of the script in a stand alone script and it removes totally different duplicates so i am confused as to why the delete duplicates part removes duplicates differently. Any ideas?
If i run the following
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> datetime <SPAN class="keyword token">import</SPAN> datetime <SPAN class="keyword token">as</SPAN> d
<SPAN class="keyword token">import</SPAN> logging<SPAN class="punctuation token">,</SPAN> os
startTime <SPAN class="operator token">=</SPAN> d<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
start_time <SPAN class="operator token">=</SPAN> time<SPAN class="punctuation token">.</SPAN>time<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\\Users\\***\\AppData\\Roaming\\Esri\\ArcGISPro\\Favorites\\***.sde"</SPAN>
<SPAN class="comment token"># Get a list of all the tables.</SPAN>
tableListA <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListTables<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'DSD.DBO.SubdivisionList'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Loop through the list and run truncate</SPAN>
<SPAN class="keyword token">for</SPAN> tableA <SPAN class="keyword token">in</SPAN> tableListA<SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>TruncateTable_management<SPAN class="punctuation token">(</SPAN>tableA<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#SDE tables and feature classes</SPAN>
tableA <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\\Users\\SubdivisionList'</SPAN> <SPAN class="comment token">#table that gets updated from ORN and Centerline</SPAN>
tableB <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\\Subdivision_boundaries'</SPAN>
tableC <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\PreliminarySubs'</SPAN>
tableD <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Users\Official_Subdivision_Names"</SPAN>
<SPAN class="comment token">####Compare and inject missing street names from ORN table</SPAN>
tableAList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableA<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
tableAList<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> cursor
<SPAN class="comment token">#list of fields whose will need to be imported into tableA</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#list of values from tableA to inject into tableC</SPAN>
ids <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableC<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SUBNAME'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> tableAList<SPAN class="punctuation token">:</SPAN>
ids<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#create insert cursor variable</SPAN>
insertCursor <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>tableA<SPAN class="punctuation token">,</SPAN>fields<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#loop through items in ids list and insert into table</SPAN>
<SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> ids<SPAN class="punctuation token">:</SPAN>
insertCursor<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> insertCursor
<SPAN class="keyword token">del</SPAN> ids
<SPAN class="comment token">###Compare and inject missing street names and Status field from centerline</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableA<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Year'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
tableAList<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Year'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#list of values from tableB to inject into tableA</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableB<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Year'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
ids<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Finihsed Comparing and inject missing street names from Preliminary Plats"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">'(Elapsed time: '</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>d<SPAN class="punctuation token">.</SPAN>now<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">-</SPAN> startTime<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">')'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">###### Compare replicated Subnames From SDE</SPAN>
<SPAN class="comment token">######</SPAN>
table1List <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
table1List<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#list of fields whose will need to be imported into table1</SPAN>
<SPAN class="comment token">#list of values from table1 to inject into table3</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>tableD<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Year'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">not</SPAN> <SPAN class="keyword token">in</SPAN> table1List<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Finihsed Comparing and inject missing Subs names from replicated Subnames From SDE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Deletes duplicate records after merging centerline and ONR</SPAN>
fc <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\\Users\\SubdivisionList'</SPAN>
fields1 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'OBJECTID'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'PLAT_NAME'</SPAN><SPAN class="punctuation token">]</SPAN>
table_rows <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> fields1<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor1<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor1<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">in</SPAN> table_rows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Deleting record: OBJECTID = {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
cursor1<SPAN class="punctuation token">.</SPAN>deleteRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
table_rows<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> table_rows
<SPAN class="keyword token">del</SPAN> cursor1
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>It removes only these
Deleting record: OBJECTID = 1817
Deleting record: OBJECTID = 1883
Deleting record: OBJECTID = 1938
Deleting record: OBJECTID = 1939
Deleting record: OBJECTID = 2150
Deleting record: OBJECTID = 2151
Deleting record: OBJECTID = 2152
Deleting record: OBJECTID = 2153
Deleting record: OBJECTID = 2154
Deleting record: OBJECTID = 2155
Deleting record: OBJECTID = 2156
Deleting record: OBJECTID = 2157
Deleting record: OBJECTID = 2158
Deleting record: OBJECTID = 2159
Deleting record: OBJECTID = 2160
Deleting record: OBJECTID = 2161
Deleting record: OBJECTID = 2162
Deleting record: OBJECTID = 2163
Deleting record: OBJECTID = 2164
Deleting record: OBJECTID = 2165
Deleting record: OBJECTID = 2166
Deleting record: OBJECTID = 2167
If I just run the deleterows after the above script it deletes more. The delete row in the above script should delete all the duplicates..?
import arcpy
fc = r'C:\\Users\\SubdivisionList'
fields = ['OBJECTID', 'PLAT_NAME']
table_rows = []
with arcpy.da.UpdateCursor(fc, fields) as cursor:
for row in cursor:
if row[1:] in table_rows:
print ("Deleting record: OBJECTID = {}".format(row[0]))
cursor.deleteRow()
else:
table_rows.append(row[1:])
del table_rows <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>It deletes
Deleting record: OBJECTID = 11
Deleting record: OBJECTID = 311
Deleting record: OBJECTID = 419
Deleting record: OBJECTID = 545
Deleting record: OBJECTID = 640
Deleting record: OBJECTID = 945
Deleting record: OBJECTID = 976
Deleting record: OBJECTID = 1003
Deleting record: OBJECTID = 1076
Deleting record: OBJECTID = 1103
Deleting record: OBJECTID = 1286
Deleting record: OBJECTID = 1518
Deleting record: OBJECTID = 1705
Deleting record: OBJECTID = 1884
Deleting record: OBJECTID = 1951
Deleting record: OBJECTID = 2069
Deleting record: OBJECTID = 2071
