This is my first post here, so I apologize if I should post somewhere else. I think I have a simple question, but I can't figure it out.
I have a city boundary shapefile that may have been created by freehand, or possibly by older parcel data. The current file does not match up with my current parcel data. If I use the boundary to clip or select the correct parcels I end up with slivers of the bordering parcels, or possibly have some skipped over. I would like to be able to either snap my existing boundary file to the existing parcel lines, or create a new boundary file based on selected parcels. If I create a boundary by parcels, I need to be able to fill in holes due the areas in the city that are not parcels such as right-of-way. Does anyone recommend a workflow?
Thank you.
