I attempted to modify a sample code to remove just one layer from one of the two data frames, "Primary", I have in multiple mxds, all stored in the same folder. This code runs, but does not actually remove the layer, "Dams", from the two text mxds, stored in the folder, RemoveLayers1. I've specified upper, considering Dams starts with a cap D, but maybe it requires a diff command when caps are mixed with lower case.I'm hoping someone can see what I'm missing. I would expect the code to provide an error message; not just fail to remove the layer.import arcpy import os import glob mxds_path = r'C:\\Temp\\removelayers1\\' layer_name = r'Dams' data_frame = r'Primary' layers = [] mxds = [] for infile in glob.glob(os.path.join( mxds_path, "*.mxd" )): mxd = arcpy.mapping.MapDocument(infile) print "removing Dams layer from " + infile for df in arcpy.mapping.ListDataFrames(mxd, data_frame): for lyr in arcpy.mapping.ListLayers(mxd, "", df): #print lyr if lyr.name.upper() == layer_name: print 'Remove layer ' + layer_name arcpy.mapping.RemoveLayer(df, lyr) #for mxd_name in mxds: #mxd = arcpy.mapping.MapDocument(mxds_path + mxd_name) #print 'removing layer for ' + mxd_name # mxd.save()
Ken
