I have properly configured the dgrid sample to load all of the map features that are loaded in the map. I am now trying to incorporate this into my main application and I cannot figure out why it will not load the dgrid. I have copied everything over so I'm not sure why it isn't working. I am fairly new to the JS API and any assistance would be great. Thank You,GeoffHere is my code: ready(function(){ parser.parse(); // create the dgrid window.grid = new (declare([Grid, Selection]))({ columns: { "OBJECTID": "OBJECTID", "NAME": "Name", "OWNER": "Owner", "COUNTY": "County", "LATITUDE": "Latitude", "LONGITUDE": "Longitude" //"median": { "label": "Median Net Worth", "formatter": dojoNum.format }, //"over1m": { "label": "Households Net Worth > $1M", "formatter": dojoNum.format } } }, "grid"); // add a click listener on the ID column grid.on(".field-OBJECTID:click", selectState); var bounds = new Extent({ "xmin": 1292510.8077427894, "ymin": 60762.840879261494, "xmax": 2759293.81036745, "ymax": 1233497.6866797954, "spatialReference": { "wkid": 3361 } }); window.map = new Map("map", { extent: bounds, logo:false }); var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer(""); map.addLayer(tiledMapServiceLayer var content = "<b>Name</b>: ${NAME}" + "<br /><b>Owner</b>: ${OWNER}" + "<br /><b>County</b>: ${COUNTY}" + "<br /><b>Acres</b>: ${ACRES}" + "<br /><b>Game Zone</b>: ${GAMEZONE}" + "<br /><b>DNR Region</b>: ${DNRREGION}" + "<br /><b>Latitude</b>: ${LATITUDE}" + "<br /><b>Longitude</b>: ${LONGITUDE}"; var infoTemplate = new InfoTemplate("Dove Field", content); window.statesUrl = ""; window.outFields = ["OBJECTID", "NAME", "OWNER", "COUNTY", "LATITUDE", "LONGITUDE"];//NEED TO ADD IN URL AFTER ADDING FIELD var fl = new FeatureLayer(window.statesUrl, { id:"states", mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["OBJECTID", "NAME", "OWNER", "COUNTY", "LATITUDE", "LONGITUDE"],//NEED TO ADD IN URL AFTER ADDING FIELD infoTemplate: infoTemplate, }); fl.on("load", function () { fl.maxScale = 0; // show the states layer at all scales fl.setSelectionSymbol(new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 20).setColor('#700000')); }); // fl.on("click", selectGrid); var scalebar = new Scalebar({ map: map, scalebarUnit: "dual", attachTo:"bottom-center" }); fl.on("mouse-over", function () { map.setMapCursor("pointer"); }); fl.on("mouse-out", function () { map.setMapCursor("default"); }); map.addLayers([fl]); map.on("load", function (evt) { domStyle.set(registry.byId("mainWindow").domNode, "visibility", "visible"); populateGrid(Memory); // pass a reference to the MemoryStore constructor }); map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return { layer: layer.layer, title: layer.layer.name }; }); if (layerInfo.length >= 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); function populateGrid(Memory) { var qt = new QueryTask(window.statesUrl); var query = new Query(); query.where = "1=1"; query.returnGeometry = false; query.outFields = window.outFields; qt.execute(query, function (results) { var data = array.map(results.features, function (feature) { return { "OBJECTID": feature.attributes[window.outFields[0]], "NAME": feature.attributes[window.outFields[1]], "OWNER": feature.attributes[window.outFields[2]], "COUNTY": feature.attributes[window.outFields[3]], "LATITUDE": feature.attributes[window.outFields[4]], "LONGITUDE": feature.attributes[window.outFields[5]] } }); window.grid.renderArray(data) }); } // fires when a row in the dgrid is clicked function selectState(e) { // select the feature var fl = map.getLayer("states"); var query = new Query(); query.objectIds = [parseInt(e.target.textContent)]; //query.objectIds = [parseInt(e.target.innerHTML)]; fl.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (result) { if (result.length) { // re-center the map to the selected feature //window.map.centerAt(result[0].geometry.getExtent().getCenter()); window.map.centerAt(result[0].geometry); } else { console.log("Feature Layer query returned no features... ", result); } }); } // fires when a feature on the map is clicked - ORIGINAL CODE function selectGrid(e) { var id = e.graphic.attributes.OBJECTID; // select the feature that was clicked var query = new Query(); query.objectIds = [id]; var states = map.getLayer("states"); states.selectFeatures(query, FeatureLayer.SELECTION_NEW); // select the corresponding row in the grid // and make sure it is in view grid.clearSelection(); grid.select(id); grid.row(id).element.scrollIntoView(); } }); });[HTML] <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width: 100%; height: 100%;"> <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'"> <div id="title">Pier and Bank Locator</div> <div id="queries"> <button id="pierBtn" class="buttons" type="button">Pier</button> <button id="bankBtn" class="buttons" type="button">Bank</button> <button id="handicapBtn" class="buttons" type="button">Handicap Access</button> <button id="restroomBtn" class="buttons" type="button">Restrooms</button> </div> <div id="search" class="search"> <input id="queryNameTxt"type="text" placeholder="Enter Name Here" > <button id="queryNameBtn" class="queryButton" type="button">Search</button> </div> <div id="filterDropDown" data-dojo-type="dijit/form/DropDownButton"> <span>Choose Filter</span> <div data-dojo-type="dijit/TooltipDialog"> <label for="name">Handicap Access</label><br> <label for="hobby">Restrooms</label> <label for="hobby">Picnic Shelter</label> <label for="hobby">Restrooms</label> </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"> <div id="legendPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="title:'Legend', selected:true"> <div id="legendDiv"></div> </div> </div> <div id="logo" class="logo"> <img src="images/DNRcolorRGB.jpg" width="40" height="50"> </div> </div> <div id="footer" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'"> <div id="grid"></div> </div> </div> </body>[/HTML]
