I'm hoping someone can help me. I have received some LAS files which I am able to bring into arcgis pro. I have generated a stats text file for the dataset in ArcGIS Pro but while it gives me info on the types of return etc, it gives no information on the point density of the las files. Is this information available? Also do I need to save it as a text file in order to view it? I have done the same process using Arcmap and was able to get basic information on the las dataset such as point spacing simply by calculating the statistics. I have attached a copy of the stats file I generated.
Many thanks in advance
