I'm trying to use this "Select" script from https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fpro.arcgis.com%2Fen%2Fpro-app%2Ftool-reference%2Fanalysis…
but it keeps giving me the following error.
File "<string>", line 10, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\analysis.py", line 91, in Select
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\analysis.py", line 88, in Select
retval = convertArcObjectToPythonObject(gp.Select_analysis(*gp_fixargs((in_features, out_feature_class, where_clause), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.ERROR 000732: Input Features: Dataset C:\arcGIS_Shared\Python\PythonTestScript.gdb\CAPatients does not exist or is not supportedFailed to execute (Select).
And Here is the script I'm using:
# Import system modules
import arcpy
# Set local variables
in_features = r"C:\arcGIS_Shared\Python\PythonTestScript.gdb\CAPatients"
out_feature_class = r"C:\arcGIS_Shared\Python\PythonTestScript.gdb\Geocoded2"
where_clause = '"Age" = \'62\''
# Execute Select
arcpy.Select_analysis(in_features, out_feature_class, where_clause)
In the script above, the datatype for "Age" is "long"; but I have also tried replacing "Age" with "Zip_Code", which is "text".
Anyone have any ideas what I'm doing wrong or missing?
