my search widget uses both geocoding service and two feature sources. However, I m having trouble having , it highlights the ESRI geocoder as the first source of search instead of ALL.
How do I make the ALL the default search so it searches all sources. Thanks in advance
// Add the layer to the map
var trailsLayer = new FeatureLayer({
map.add(trailsLayer); // Optionally add layer to map
var trailsLayerr = new FeatureLayer({
map.add(trailsLayerr); // Optionally add layer to map
var view = new MapView({
container: "viewDiv",
map: map,
zoom: 17,
center: [0.46564130, 51.736810] // longitude, latitude
// Search
var search = new Search({
view: view
search.defaultSource.withinViewEnabled = true; // Limit search to visible map area only
view.ui.add(search, "top-right"); // Add to the map
// Add the trailheads as a search source
search.sources.push({
featureLayer: trailsLayer,
searchFields: ["Postcode", "UPRN", "ADDRESS" ],
displayField: "ADDRESS",
exactMatch: false,
outFields: ["*"],
resultGraphicEnabled: true,
placeholder: "example: CM2 0HU",
popupTemplate: { // autocasts as new popupTemplate()
title: "Post Code: {Postcode}</br>UPRN: {UPRN}</br>ADDRESS: {ADDRESS}",
overwriteActions: true
featureLayer: trailsLayerr,
exactMatch: false,
outFields: ["*"],
});</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
