I want to add a layer on a map from a local service created from a map package. Here is the code:
private async void LoadOfflineMapPackage()
try
string mpkPath = @D:\mappackages\localservices\test.mpk;
LocalMapService localMapService = new LocalMapService(mpkPath, 100000);
await localMapService.StartAsync();
ArcGISDynamicMapServiceLayer layer = new ArcGISDynamicMapServiceLayer()
ID = "localServiceLayer",
ServiceUri = localMapService.UrlMapService
MyMapView.Map.Layers.Add(layer);
catch (Exception ex)
MessageBox.Show("Unable to create local service: " + ex.Message);
I get the following error on the StartAsync method:
Esri.ArcGISRuntime.Http.ArcGISWebException was caught
HResult=-2146233088
Message=Error code '500' : 'Failed to create service test MapServer. Worker process 'test_host' exited while attempting to service request (attempt 1 of 1): endpoint='admin' headers={} params={filePath=d:\mappackages\localservices\test.mpk, maxRecords=100000, name=test, outputDir=C:\Users\myuser\AppData\Local\Temp\arcgisruntime_12804\test, type=MapServer, virtualDir=http://127.0.0.1:50000/vnCNdS/outputdir/test} res='create' post=0 Crash dump path='
Source=Esri.ArcGISRuntime
Code=500.0
StackTrace:
at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__2.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
at Esri.ArcGISRuntime.Http.ArcGISHttpClient.<GetStringAsync>d__0.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
at Esri.ArcGISRuntime.LocalServices.LocalService.<StartServiceInternal>d__2.MoveNext()
at OfflineApp.MainWindow.<LoadOfflineMapPackage>d__8.MoveNext() in d:\ArcGISRuntimeApps\OfflineApp\OfflineApp\MainWindow.xaml.cs:line 172
InnerException:
I have tried many things, but still have not been able to get it to run.
Does anyone know what the problem is?
Ed
