I want to upgrade multiple PC's on our network using the command line I see it is possible HERE: Installing ArcGIS Desktop silently—Help | ArcGIS Desktop
However the help docs reference "Concurrent Use" I do not want to use concurrent use my previous installations are single use installs. will this method still work? if not how will the installer know to use a new auth # to switch to concurrent use?
my end goal is to paste(remotely) the setup.exe on the C:\ drive (of all my client PC's) and schedule windows task to run the batch script at say midnight to upgrade the installs to 10.5.1 without any need for user interaction.
Also, the ESRI LICENSE HOST ='mahcine_Name'.... this will need to call each unique PC name to locate the license manager... how can I can through the dynamic variable int there to use the local machine name? Or do I need to make 20+ unique copies of this and for each use the specific host machine?
EDIT: I see the SEAT_PREFERENCE=Fixed can be used for a single use license.
EDIT: The dynamic PC name can use the following: %COMPUTERNAME%
all advice is welcomed.
<setup staging location>\setup.exe ESRI_LICENSE_HOST=GIS SOFTWARE_CLASS=Professional SEAT_PREFERENCE=Float DESKTOP_CONFIG=TRUE INSTALLDIR1=C:\python27 /qb
