My map has 21 levels, and At begin, I set maxZoom on constructor at level 19.this is my code.var lods = [ {"level" : 0, "resolution" : 156543.03392800014, "scale" : 5.91657527591555E8}, {"level" : 1, "resolution" : 78271.51696399994, "scale" : 2.95828763795777E8}, {"level" : 2, "resolution" : 39135.75848200009, "scale" : 1.47914381897889E8}, {"level" : 3, "resolution" : 19567.87924099992, "scale" : 7.3957190948944E7}, {"level" : 4, "resolution" : 9783.93962049996, "scale" : 3.6978595474472E7}, {"level" : 5, "resolution" : 4891.96981024998, "scale" : 1.8489297737236E7}, {"level" : 6, "resolution" : 2445.98490512499, "scale" : 9244648.868618}, {"level" : 7, "resolution" : 1222.992452562495, "scale" : 4622324.434309}, {"level" : 8, "resolution" : 611.4962262813797, "scale" : 2311162.217155}, {"level" : 9, "resolution" : 305.74811314055756, "scale" : 1155581.108577}, {"level" : 10, "resolution" : 152.87405657041106, "scale" : 577790.554289}, {"level" : 11, "resolution" : 76.43702828507324, "scale" : 288895.277144}, {"level" : 12, "resolution" : 38.21851414253662, "scale" : 144447.638572}, {"level" : 13, "resolution" : 19.10925707126831, "scale" : 72223.819286}, {"level" : 14, "resolution" : 9.554628535634155, "scale" : 36111.909643}, {"level" : 15, "resolution" : 4.77731426794937, "scale" : 18055.954822}, {"level" : 16, "resolution" : 2.388657133974685, "scale" : 9027.977411}, {"level" : 17, "resolution" : 1.1943285668550503, "scale" : 4513.988705}, {"level" : 18, "resolution" : 0.5971642835598172, "scale" : 2256.994353}, {"level" : 19, "resolution" : 0.29858214164761665, "scale" : 1128.497176}, {"level" : 20, "resolution" : 0.1492910708238083, "scale" : 564.248588}, {"level" : 21, "resolution" : 0.0746455354119042, "scale" : 282.124294} ]; map = new Map("map",{ lods: lods, center:[100.543623,13.703039], zoom: 18, maxZoom: 19, fadeOnZoom: true });
On the later... I need to set maxZoom again to different level. But I can't find the way to set that.In api reference: https://developers.arcgis.com/javascript/jsapi/map-amd.html I found only getMaxZoom() method, but it don't have setMaxZoom() method.Is it possible to set maxZoom again after set it at constructor.thanks for help
