I did a bit searching on the Internet and here's my practice:
import arcpy as ap
import glob
# this will give you a Python list object that you can use to batch process all of your files
# just insert the path to your folder holding the netCDF files
cdfList = glob.glob('F:\\NLDAS 2-primary forcing\\test\\*.nc')
print cdfList
# now you can loop through your list and process each file one at a time
for cdf in cdfList:
print "Now processing: " + cdf
ap.md.MakeNetCDFRasterLayer(cdf,"pevapsfc","lon","lat",cdf+"_r")
print "Done!"It ran smoothly but I didn't see anything on my output folder. Did I do something wrong?
