I have configured the Print Widget to print secured services with WebApp Builder. The tool works fine except that it will print only when there is no more than two services showing in the map. When I select more than two services I have the "Error, Try again" message.
Did someone encountered that error and found how to get around it?
Thank you!
Line Champagne
