I am new to coding. I am trying to write a script that will allow me to export multiple map documents to PDF using Python. I found some code to do just that at the following ESRI help link 44242 - Export map documents to PDF using Python . However when I try to run it I get the below Runtime Error message. The only thing I changed from the original code was the workspace pathway. Thank you very much, Ana
>>> import arcpy, os
... arcpy.env.workspace = ws = "C:\Users\00177153\Desktop\ArcPy"
... mxd_list = arcpy.ListFiles("*.mxd")
... for mxd in mxd_files:
... current_mxd = arcpy.mapping.MapDocument(os.path.join(ws, mxd))
... pdf_name = mxd[:-4] + ".pdf"
... arcpy.mapping.ExportToPDF(current_mxd, pdf_name)
... del mxd_files
Runtime Error
File "<string>", line 7, in <module>
NameError: name 'mxd_files' is not defined
