I have a python script that i would like to turn on some layers "if they exsist", if they don't exsist i would like for the script to continue to run. The current script won't run it give me an error File "<string>", line 8, in <module>IndexError: list index out of rangeThis script will be used on about 5 mxd for a single project.Note: some mxd don't have the layer "URNBAN_12" OR "RURAL_12"The mxd with these layers added to the TOB run just fine with this script, but some mxd don't have these layers on the mxd and therefore it stops at line 8..So how can i make the script continue to run past line 8?import arcpy import os arcpy.env.overwriteOutput = True mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "URBAN_12")[0] UR = "URBAN_12" if arcpy.Exists(UR): lyr.visible = True lyr = arcpy.mapping.ListLayers(mxd, "Rural_12")[0] RU = "Rural_12" if arcpy.Exists(RU): lyr.visible = True mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "SUBJECT_PROPERTY")[0] arcpy.env.workspace = os.path.dirname(mxd.filePath) wp = os.path.dirname(mxd.filePath) del mxd mxd = arcpy.mapping.MapDocument("CURRENT") lyr = arcpy.mapping.ListLayers(mxd, "SUBJECT_PROPERTY")[0] lyrpath = lyr.workspacePath arcpy.env.qualifiedFieldNames = False SP = "SUBJECT_PROPERTY" lyr.replaceDataSource(wp, "SHAPEFILE_WORKSPACE", SP, True ) df.extent = lyr.getSelectedExtent() df.scale = 2000 arcpy.RefreshActiveView() arcpy.RefreshTOC() del df mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "1_2")[0] S12 = "1_2" lyr.replaceDataSource(wp, "SHAPEFILE_WORKSPACE", S12, True ) if arcpy.Exists(S12): df.extent = lyr.getSelectedExtent() df.extent = lyr.getSelectedExtent() arcpy.RefreshActiveView() arcpy.RefreshTOC() I appreciate any help.Thanks.
