I ran the space time cube,but it always show the wrong message.
File "<string>", line 1, in <module>
File "d:\arcgispro\pro\Resources\arcpy\arcpy\stpm.py", line 171, in CreateSpaceTimeCube
raise e
File "d:\arcgispro\pro\Resources\arcpy\arcpy\stpm.py", line 168, in CreateSpaceTimeCube
retval = convertArcObjectToPythonObject(gp.CreateSpaceTimeCube_stpm(*gp_fixargs((in_features, output_cube, time_field, template_cube, time_step_interval, time_step_alignment, reference_time, distance_interval, summary_fields, aggregation_shape_type, defined_polygon_locations, location_id), True)))
File "d:\arcgispro\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError:
File "<string>", line 1158, in execute
File "D:\ArcGISPRO\PRO\Resources\ArcToolbox\Scripts\SSCube.py", line 90, in __init__
self.__initialize(cubeObj)
File "D:\ArcGISPRO\PRO\Resources\ArcToolbox\Scripts\SSCube.py", line 136, in __initialize
self.dataset = NET.Dataset(self.path, self.mode)
File "netCDF4\_netCDF4.pyx", line 1811, in netCDF4._netCDF4.Dataset.__init__ (netCDF4\_netCDF4.c:12631)
OSError: Permission denied
Failed to execute (CreateSpaceTimeCube).
