Does anyone know if database views are supported in operations dashboard? I've tried adding a published database view to ArcGIS Online, but when I add the web map to Dashboard, it won't accept the view as a datasource... I have to point out that the Database view is a table.
http://srv8.kort.fo/arcgis/rest/services/demo/torshavnar_vegristir_stats_demo/MapServer/11/query?where=1%3D1&text=&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=&spatialRel=esriSpatialRelIntersects&relationParam=&outFields=*&returnGeometry=true&maxAllowableOffset=&geometryPrecision=&outSR=&returnIdsOnly=false&returnCountOnly=false&orderByFields=&groupByFieldsForStatistics=&outStatistics=&returnZ=false&returnM=false&gdbVersion=&returnDistinctValues=false&returnTrueCurves=false&resultOffset=&resultRecordCount=&f=html
Hi Lars,
Database views and tables are supported with the Operations Dashboard, but they must be added as External Data Sources. See the section 'External data sources' in the below link:
Data sources in the operation view—Operations Dashboard for ArcGIS | ArcGIS
Hi Jake,
Thank you for a fast response, that did the trick! 🙂
Lars
Přihlášení členové mohou přispívat, sledovat aktualizace a další. Jste tu noví? Zaregistrujte si bezplatný účet.
