Hi everyone,Has anyone figured out a way to add a Menu to the MAIN (Root) menu toolbar using Addins?So a menu in between File and EDIT or after HELP.I know you can modify the Main Toolbar via ESRIRegAsm com object w/ deployed MSI installable.. but what about ADDINS?I can Create a new Menu ... but then unable to do anything from there...(button wise) in an Extention Addin Setting: Dim TopMenuBar As ESRI.ArcGIS.Framework.ICommandBar
TopMenuBar = GetToolbarByName(My.ArcMap.Application, "esriArcMapUI.MxMenuBar")
TopMenuBar.CreateMenu("Menu TEST", 1)
The Main Toolbar {56599DD3-E464-11D1-9496-080009EEBECB}esriArcMapUI.MxFileMenuThanks, in advance.
