I am trying to resample multiple rasters with the "Resample_management" ArcPy function.The code below works perfectly:import arcpy from arcpy import sa arcpy.gp.overwriteOutput=True arcpy.CheckOutExtension("spatial") import glob Input=glob.glob("D:\Freelancer\oDesk\Create-ArcPy-Scripts\TestFiles\*tif") for i in Input: arcpy.Resample_management(i, i+"_1000.tif", "1000 1000", "BILINEAR")But it saves the output files in the same directory with the input ones. To change this, I modified it a bit.import arcpy from arcpy import sa arcpy.gp.overwriteOutput=True arcpy.CheckOutExtension("spatial") import glob Output="D:/Freelancer/oDesk/Create-ArcPy-Scripts/OutputFiles/" Input=glob.glob("D:/Freelancer/oDesk/Create-ArcPy-Scripts/TestFiles/*tif") for i in Input: arcpy.Resample_management(i, "'D:/Freelancer/oDesk/Create-ArcPy-Scripts/OutputFiles/%s_1000.tif' % i", "1000 1000", "BILINEAR")But this throws an error:Traceback (most recent call last): File "D:\Freelancer\oDesk\Create-ArcPy-Scripts\testscript-2.py", line 11, in <module> arcpy.Resample_management(i, "'D:/Freelancer/oDesk/Create-ArcPy-Scripts/OutputFiles/%s_1000.tif' % i", "1000 1000", "BILINEAR") File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 12407, in Resample raise e ExecuteError: ERROR 999999: Error executing function. Failed to execute (Resample).
What am I doing wrong?
