Hi everyone,This may seem like an easy one but I cannot quite find the way:When setting the environments, I want to use one of the parameters ("InputZ") as a mask for the different processes within the script. It works fine like this:arcpy.env.mask = r"D:\PROGRAMMES\LFP_Source_Rocks\ArcGIS\00_LFP_GLOBAL_MODEL\INPUT.gdb\Maas_Bathymetry"but I want this:arcpy.env.mask = (InputZ)using ArcView 10.0here is the beginning of the code:import arcpy import string from arcpy import env arcpy.env.overwriteOutput=True from arcpy.sa import * arcpy.CheckOutExtension("Spatial") # Set the output location, extent and Mask OutLocation = arcpy.GetParameterAsText(0) arcpy.env.extent = arcpy.Extent(-180.0, -90.0, 180.0, 90.0) arcpy.env.mask = (InputZ) # Input strings and variables StageAge = str(arcpy.GetParameterAsText(1)) BSS = arcpy.Raster(arcpy.GetParameterAsText(2)) InputLatitude = arcpy.Raster(arcpy.GetParameterAsText(3)) InputZ = arcpy.Raster(arcpy.GetParameterAsText(4)) InputCountrylines = arcpy.GetParameterAsText(5) NPPEquation = str(arcpy.GetParameterAsText(6))Any help will be greatly appreciated.Many thanks
