I'd think this one should be easy. How do I use my input parameters, to automatically update my Calculate Field expression, within a Python script? I thought I had it, but I receieve an error. In my script I would like portions of the expression in the Calculate Field line to change as my input parameters change. If I force the expression like this, it works: "( !SUM_POP10! / !SUM_SUM_POP10! )*100", "PYTHON")But I need both of the fields (either side of the "/" line) in that expression to change based upon one of my input paramters I choose, here: popfield = gp.GetParameterAsText(2) #population fieldHere is how I have it and where I beleive the Error is coming from; not sure what it doesn't like:arcpy.CalculateField_management(outputfc, percentfield, '"('+str(popfield)+'/SUM_'+str(popfield)+')*100"', "PYTHON")
Again, as the "popfield =" paramter changes, so does the expression. So as I choose a new "SUM_POPxx" field, the expression automatically changes with it.I'd appreciate any assistance. Thank you.
