Hey developers,
Attempting to have a buffer drawn around a graphic which the user has drawn on the map using the draw toolbar. Everything appears to be in order and the developer console returns no errors. The user clicks the buffer button and nothing happens.
Below is the method invoked when the user clicks the buffer button.
_createBuffers: function () {
this.inherited(arguments);
//Internal variables
var params = new BufferParameters();
var gsvc = new GeometryService();
var bufferGraphicsLayer = new GraphicsLayer();
var gsvc = new GeometryService('http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer');
var graphics = new Graphic();
//Enable Button
this._enableBtn(this.btnApply, true);
//getGeometires method to pull geometries from AOI drawn into the graphics layer.
graphics = this._graphicsLayer.graphics;
var geometries = graphicsUtils.getGeometries(graphics);
//parameters for the buffer <-- Need error handling for if user attempts to run the buffer without a drawn AOI
params.bufferSpatialReference = new esri.SpatialReference({"wkid": this.map.spatialReference.wkid});
params.distances = [document.getElementById("distance").value];
params.geometries = geometries; //<-------------------------- Potential Issue with buffer #1; geometries issue.
params.geodesic = false;
params.outSpatialReference = new esri.SpatialReference({ "wkid": this.map.spatialReference.wkid });
params.unionResults = true;
params.unit = GeometryService[document.getElementById("unit").value];
//Place here the invoking of the geometry service and the creation of the symbols for the buffer layer.
gsvc.buffer(params, showBuffer);
//Function to draw buffers
function showBuffer(buffer) {
// Add the buffer graphic to the map
var symbol = new SimpleFillSymbol()
.setColor(new Color([56, 102, 164, 0.4]))
.setOutline(
new SimpleLineSymbol()
.setColor(new Color([56, 102, 164, 0.8]))
bufferGraphics = new Graphic(buffer, symbol);
console.dir(bufferGraphicsLayer); //<------------------- Potential Issue with buffer #2; graphicsLayer issue.
bufferGraphicsLayer.add(bufferGraphics);
Thanks in advance!
